Date/Time: Fri, 07 Feb 2025 15:10:00 +0000
Study Subgraph Above/Below as Text Question
View Count: 561
[2021-05-25 20:36:56] |
jaxscott - Posts: 57 |
Referencing a Numbers Bar Calculated Values subgraph that has positive and negative values. I'd like to print positive values at the TOP of the numbers bar and negative values at the BOTTOM. Not quite sure how to do this? Clue? Thx
[2021-05-25 21:25:49] |
John - SC Support - Posts: 37808 |
The only way to do what you are asking is to use two copies of the Color Bar Based on Alert Condition that are Based On the Numbers Bars Calculated Values with the Input Data set to the calculated value you want. One of the studies will have an alert that reads: = ID1.SG1 < 0 And has the Draw Style set to Value on Low And the other will have an alert that reads: = ID1.SG1 >= 0 and has the Draw Style set to Value on High Refer to the following for the Color Bar Based on Alert Condition: Color Bar Based on Alert Condition And refer to the following for the Draw Style: Chart Studies: Subgraphs Tab >> Draw Style For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
