Date/Time: Wed, 26 Feb 2025 15:56:49 +0000
Do I have to leave my spreadsheet open for the Spreadsheet Alert to work proporly?
View Count: 359
[2021-05-25 19:10:36]
SabikiSensei - Posts: 76
If I close my spreadsheet, I'm assuming the signal won't show up anymore?
I'm getting the message, "This spreadsheet cannot be closed since a study is referencing it. Do you want to remove the study that references this spreadsheet?"
[2021-05-25 19:21:21]
John - SC Support - Posts: 38179
Correct. If you close the spreadsheet that is setup for a signal of some type, then you will not get that signal.
You are trying to close the spreadsheet directly that is part of the a Spreadsheet Study. It is best to remove the study from the chart, which will remove the Spreadsheet as well.
