Date/Time: Wed, 26 Feb 2025 15:49:03 +0000
choosing data
View Count: 469
[2021-05-25 18:41:35]
Galmik - Posts: 37
Hi i am a little confused even after reading some posts. So please help.
So 1) i want to trade stocks that belong to DJI NSDAQ and SPY also in the coming months i want to trade FUTURES so tell me if i can upgrade data afterwards. SO which package shall i choose?
2) I want to use market profile (TPO charts) in stocks i choose to trade
3) i Use interactive brokers as broker so tell me how i can connect the two plattforms. I aleady communicated with interactive brokers and i made all necessary moves on their side to connect sierra.
4)Can i use two screens on the package you will suggest me to buy?
Thank you for your time to reply
[2021-05-25 19:17:22]
John - SC Support - Posts: 38179
1. If you want to get the stock data from us, then you will need to use the Sierra Chart Exchange Data Feed and enable the U.S. Equities exchange. To do this, follow these isntructions:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions
You can always add the Futures data later. The CME Group and EUREX data are part of the Denali Exchange Data Feed.
2. You will need to use Package 5 in order to have access to the TPO profiles.
3. To connect Sierra Chart to Interactive Brokers follow these instructions:
Interactive Brokers Trading Service: Setup Instructions
4. You can use multiple monitors with Sierra Chart. The easiest way to do so is to detach a chart and move it to the screen you want. Refer to the following information for this:
Detaching and Attaching Chart Windows
There is also the option to use multiple sub-instances. Refer to the following for this:
Using DTC Server for Data and Trading in Another Sierra Chart Instance: Instructions For Sharing Data Using Sub Instances (Easiest And Recommended Method)
