Date/Time: Mon, 25 Nov 2024 20:52:02 +0000
CFD data with FXCM FIX
View Count: 1092
[2014-03-12 18:51:16] |
bwalks123 - Posts: 122 |
I just set up the FXCM FIX connection and was curious if there is a way to still receive CFD real time data along with the provided forex data feed without running a separate instance of SC?
[2014-03-12 22:03:00] |
No because the Live real-time data comes from your own FXCM connection.
