Date/Time: Wed, 26 Feb 2025 15:55:46 +0000
Export Trade Activity Log via command line
View Count: 663
[2021-05-25 16:11:30] |
User230940 - Posts: 121 |
Hello, I would like to export the Trade Activity Logs in real time to a database. I found nothing which makes this possible today, right? Is there a possibility to export the trade activity logs via a command line which I could use in the background with scheduled task for example. Afterwards I would import this data to my database. This would not be real time by near by. Thanks for your input best regards |
[2021-05-25 16:59:32] |
John - SC Support - Posts: 38179 |
Nothing built into Sierra Chart. You could create your own study that can get the information. Refer to the following: Automated Trading From an Advanced Custom Study: s_SCTradeOrder Structure Members Is there a possibility to export the trade activity logs via a command line which I could use in the background with scheduled task for example. Afterwards I would import this data to my database. This would not be real time by near by.
There is no keyboard shortcut that would export/save the Trade Activity Log. But, refer to the following for how to Export/Save the information in general: Trade Activity Log: Saving the Log For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-25 17:07:25] |
Hi John, thanks. Would it be possible through the DLL to access a database? regards carsten |
[2021-05-25 17:25:56] |
If you are referring to your own database, then yes. What you are creating is a fully functional C++ program that is run within Sierra Chart, so you have access to all the C++ functionality. Refer to the following: Advanced Custom Study Interface and Language (ACSIL): Introduction For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
