Date/Time: Thu, 10 Sep 2026 11:24:12 +0000
Bollinger Squeeze 2 study only displays green dots.
View Count: 1030
[2021-05-25 14:09:03]
gjockey - Posts: 51
The Bollinger Squeeze 2 study chart should show red or green dots depending on if the symbol is consolidating or breaking out. The study only plots green dots. (Please see attached image). The 3 Bollinger squeeze studies were added to a chart of "GE", a low volatility stock. As you can see from the image, the Bollinger squeeze 2 study is the only one that shows green dots exclusively. To the left of the chart is the Bollinger Squeeze 2 study subgraph window. Thank You.
imageBollinger Squeeze 2.jpg / V - Attached On 2021-05-25 14:06:59 UTC - Size: 250.13 KB - 369 views
[2021-05-25 19:36:55]
John - SC Support - Posts: 47822
Keep in mind that for the Bollinger Squeeze and Bollinger Squeeze 2 the dots (Squeeze Indicator) coloring is determined by the relative values of the Keltner Bands and the Bollinger Bands. You will find the definition for these in each of the study's documentation, such as for the Bollinger Squeeze here:
Bollinger Squeeze
With the default settings in the Bollinger 2 study, particularly the Bollinger Bands Multiplier of 10 in comparison to the Keltner Bands Multiplier of 2, you are going to get the largely green dots. If you set the Multipliers to be more similar, then you will see differences in the colors of the dots.
