Date/Time: Fri, 07 Feb 2025 14:45:57 +0000
Creating an audio alert for Extend to Future Bar Close Crossing.
View Count: 455
[2021-05-24 21:06:36] |
TriStar Trading - Posts: 147 |
I'm wanting to create audio alerts when the above named line type is touched by price. I'm generating the actual signal subgraph in an ASCIL study but using the Color Bar Based on Alert Condition to access the signal subgraph and do the line generation. Subgraph 2 In the Color Bar Based on Alert Condition does not seem to be recognized on a simple alert condition. Is there maybe an array somewhere that can be accessed which contains all the prices for each line? I just need to get access to the working lines prices so I can que off that for an alert. If I generated the lines in the ASCIL would I be able to access the line properties to keep track of the prices? Any help is appreciated. Thanks!
[2021-05-24 21:12:52] |
John - SC Support - Posts: 37808 |
Do a search in the Functions section for ACSIL for the term "Future" and you will see all the available functions, which allow you to access existing lines as well as create new ones: https://www.sierrachart.com/index.php?page=doc/ACSIL_Members_Functions.html For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
