Date/Time: Wed, 26 Feb 2025 18:04:29 +0000
US Options Trading
View Count: 547
[2021-05-24 16:05:50] |
User206215 - Posts: 5 |
Hello Sierra Support, I am interested in using Sierra Chart to day trade US options. 1. Does Sierra Chart support US options trading DOM and options trading within the platform? 2. Which package and data services are required for real-time US options? 3. Does Sierra show market and limit orders? Thank you. |
[2021-05-24 22:59:28] |
Hello Sierra, Has this post been responded to or just moved to a different section on the Support Board? Thank you |
[2021-05-25 19:42:38] |
Sierra_Chart Engineering - Posts: 18569 |
Are you referring to futures options or stock options? We need to know what exchanges these options are on. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-25 23:07:59] |
Hello Sierra, Stock options traded on NASDAQ, NYSE, etc. |
[2021-05-31 00:11:00] |
Hello Sierra, An update please??? |
[2021-05-31 01:14:52] |
In the case of US stock options there is not good support for market data or trading them from Sierra Chart. The only possibility would be through the supported Interactive Brokers trading service but we would not recommend that.
[2021-05-31 04:15:56] |
Hello Sierra, Thank you. |
