Date/Time: Wed, 26 Feb 2025 14:28:43 +0000
charts frozen
View Count: 410
[2021-05-24 12:56:32] |
User797992 - Posts: 18 |
Hi, looking at ES and CL, both are frozen? If I disconnect then reconnect the chart updates, but then the price is frozen again ? Please help
[2021-05-24 13:43:45] |
John - SC Support - Posts: 38172 |
There were some recent changes that require that you update to the latest release. You can update by following these instructions: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
