Date/Time: Wed, 26 Feb 2025 15:56:49 +0000
Can't boot up.
View Count: 639
[2021-05-24 09:08:00]
pMathisen - Posts: 9
I was doing a update to my sierra chart, and when the installer program was done and sierra should start up it just quits immediately. And I got this error: INITIALIZATION ERROR: Error creating the alert manager object. If you need more help, contact Sierra Chart Support for assistance
Date Time Of Last Edit: 2021-05-24 09:36:36
imageScreenshot_2.png / V - Attached On 2021-05-24 09:07:17 UTC - Size: 3.7 KB - 163 views
[2021-05-24 13:46:36]
John - SC Support - Posts: 38179
Please go through the update process one more time for us and let us know what the result is after it is done.
[2021-05-24 15:26:18]
We need to get the Sierra4.config file, from your Sierra Chart installation folder to try to reproduce this.
You can attach it here following these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
[2021-05-24 18:17:14]
There you go.
Private File
[2021-05-26 04:45:09]
Any clue whats the problem?
[2021-05-26 06:40:21]
Sierra_Chart Engineering - Posts: 18569
We apologize for the delay. We have identified the problem. Just give us a couple of hours to implement a solution and have a new release out.
Although we need more time to understand exactly why this condition happens to begin with.
[2021-05-26 12:39:13]
We do apologize for the delay. We have this issue now resolved. Update Sierra Chart to the latest "Prerelease" following the instructions here:
This is version 2264.
[2021-05-26 12:53:48]
Actually we realize, because you cannot start Sierra Chart you cannot use the standard update instructions. Use this link:
https://download2.sierrachart.com/downloads/SierraChartFileDownloader.exe
On the installer window in the Version list box, select "Prerelease" .
