Date/Time: Wed, 26 Feb 2025 14:10:40 +0000
Consistently slower chart replay with OpenGL enabled
View Count: 607
[2021-05-22 12:56:20] |
jwick - Posts: 142 |
Hi ... I'm noticing my market replay is consistently and noticeably (close to 1/2x) slower on instances with OpenGL enabled vs ones with it disabled. My chart replay settings: Calculate at every tick / trade. 200,000 speed. Charts to Replay: All Charts (30 charts total). Bar period update speed is half of the lowest TF chart (90 second with 3 minute chart as the lowest TF). Obviously when testing between two instances (one with opengl and one without) I'm using identical chartbooks and identical code. |
[2021-05-23 00:55:26] |
Okay, this is what it is. It is not anything we can improve upon. We definitely do not recommend calculating at every tick also. That is going to be terribly slow.
[2021-05-23 11:47:47] |
Sorry I mean to say when I disable OpenGL support, even with Calculate at every tick enabled (so without changing any setting but disabling openGL), the market replay is consistently running nearly twice as fast. EDIT: Oops I didn't notice the "also" in your reply. So just confirming that a slower market replay when OpenGL is enabled is expected behavior. For personal curiosity, any ideas why that is the case? Date Time Of Last Edit: 2021-05-28 17:03:32
