Date/Time: Wed, 26 Feb 2025 14:14:24 +0000
live data feed
View Count: 501
[2021-05-21 16:20:38]
User491366 - Posts: 1
Hello, i have live funded AMP account(not professional) and i would like to connect live data feed.i only looking to trade CME E-mini and E-micro contracts.i already paid and useing sierra chart data package nr 5 and i want to keep it that way ,cause my settings are all according to it.When i made account with AMP then they connected me CQG routing service witch i would like to change now as well to TT service ,because i read it causes lot of problems. Please help me to set all this up.
[2021-05-24 14:39:55]
John - SC Support - Posts: 38172
First, the connection to TT with Sierra Chart through AMP is not supported. Therefore, you need to continue to use CQG. Hopefully AMP will support the new Direct CME Connection when we have that complete, so if they do, then you can move to that option. Until then, you really just need to use CQG (unless you want to change brokers). If you have not already done so, you would need to go through the following Setup Instructions to connect your Sierra Chart to CQG:
CQG Trading Platform Service: Setup Instructions
Second, you would need to setup the Denali Exchange Data Feed for the data you are wanting. We see that you have already done this and everything looks good on our end, so you should be getting the real-time data from the Denali Exchange Data Feed at this time.
