Date/Time: Wed, 26 Feb 2025 14:05:30 +0000
empty chartbooks after closing down SC
View Count: 476
[2021-05-21 12:47:20] |
UserOne - Posts: 40 |
Today morning I opened my chartbooks and many of them are empty. Is there a way to restore them? There is no backup of the chartbooks in te data folder. Using 2260.
[2021-05-21 13:07:19] |
That is quite unusual. Almost certainly it is caused by a system-level issue on your system. You need to access your backup chartbooks: Chartbooks (Workspaces): Accessing a Backup Chartbook File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
