Date/Time: Wed, 26 Feb 2025 13:57:29 +0000
Historical data for stocks - Intraday
View Count: 608
[2021-05-21 06:50:06] |
Fabio - Posts: 120 |
Good morning, I am using the SC Data - All Services for some backtesting on U.S. stocks, intraday. However, I can't get more than a year worth of intraday data. Every time I try to change the data range from chart setting--> data range -->From, the date changes back to the one already set and not the one I am trying to load up. Can you please help on this? Thanks, Fabio |
[2021-05-22 05:24:42] |
Refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
