Date/Time: Wed, 26 Feb 2025 13:58:48 +0000
AGN Futures not in Drop down menu for
View Count: 831
[2021-05-21 03:18:42] |
Eric Fraenkel - Posts: 4 |
Support: I'm opening an account with AGN Futures which is one of the brokers in your approved lists for "Sierra Chart Futures Order Routing Service With Data" that I intend to sign up for and I don't see them in the Clearing Firm Name drop down menu? I've just sent my funding request to Midland Trust for my IRA and then account will be open at AGN Futures. After account open I'll send the request but need to understand how to work around AGN not listed? Thanks. |
[2021-05-22 01:45:57] |
We will sort this out for you on Monday. We will have someone follow-up then.
[2021-05-24 14:04:47] |
SC Support - Posts: 1936 |
Hi Eric, AGN Futures support SC TT Order Routing through Phillip Capital Clearing, but I understand AGN work with other clearing firms too (Clearing Firms that don't support TT), can you tell us which Clearing Firm you are using? Thank you
Date Time Of Last Edit: 2021-05-24 16:00:16
[2021-05-24 16:07:43] |
They will be using Dormin Trading. Thanks
[2021-05-24 16:36:16] |
Ok well, Dorman Clearing does support TT also, so you can ask AGN Futures if they can put you on TT Order Routing through Sierra Chart (Clearing through Dorman).
