Date/Time: Wed, 26 Feb 2025 13:57:46 +0000
Delayed data on charts CBOT wheat and CME live cattle charts
View Count: 537
[2021-05-21 03:15:59] |
gretat - Posts: 11 |
http://www.sierrachart.com/image.php?Image=1621540674117.png Hello, I have chartbook with S&P 500 and Nasdaq futures charts both showing realtime data. I added a CME live cattle chart (attached) but it is showing delayed data. I believe I have live data for CME exchanges active. Would you tell me how to show the Live Cattle and the CBOT wheat data as live. Thank you! Greta |
[2021-05-21 05:36:36] |
They should be real-time unless trading has closed at the time you see delayed data. You do need to check with the exchange session times. For example Wheat closes at 14:20 US Eastern time and does not reopen until 20: 00. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
