Date/Time: Wed, 26 Feb 2025 14:29:22 +0000
RE: Rolling time frame window signal generation request
View Count: 551
[2021-05-21 01:58:37] |
User945898 - Posts: 7 |
Hi SC Support Can you tell me if my previous email "Rolling time frame window signal generation" can be done using existing sierra chart functions and studies and if so can you please guide me in the right direction. If new coding is required are you able to do this for a reasonable fee? Thank You |
[2021-05-22 05:37:37] |
You should definitely be able to accomplish anything like this using ACSIL: Table of Contents | (Advanced Custom Study/System Interface and Language (ACSIL)) Also have a look at the built-in studies to see if any of them can be used to help you with what you want to accomplish, in combination with ACSIL: Technical Studies Reference If it requires custom programming, this is not something we would have time for ourselves. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-05-22 05:39:40
