Date/Time: Wed, 16 Sep 2026 22:47:18 +0000
Flatten position at a certain time problem
View Count: 1557
[2021-05-20 20:10:23]
User715828 - Posts: 61
Today I had my Trade service log pop up at 12:58:59 with this message
Unable to Flatten or Reverse because a Position does not exist | Symbol: F.US.EPM21 | TradeAccount: 128094 | 2021-05-20 12:58:59.043 *
I've have this problem before when I actually had a position and it closed it at this time. I've looked everywhere that you suggested and was not able to find out how to stop this.
Now today I'm getting this message and I don't even have a position. Can you please help me fix this. Luckily today I did not have on a position but I do not want to be auto liquidated.
Thanks you.
[2021-05-20 20:26:54]
John - SC Support - Posts: 47917
We assume that you do not believe that you selected a Flatten option at all and that is what you are really asking - why are you getting that message when you never selected Flatten?
First, are you absolutely positive that you did not select a Flatten option, possibly through a Keyboard shortcut? Keep in mind, you can turn off Trading Keyboard Shortcuts exactly for this reason. Refer to the following:
Trade Menu: Trading Keyboard Shortcuts Enabled (Trade menu)
The other thing to check is the Global Profit/Loss Management and see if you have the option to "Flatten Positions at Set Time".
Then, on the Trade Window under the A tab is an option for "Flatten and Cancel at Set Time" as well. Make sure that is not enabled.
[2021-05-22 05:23:24]
You can determine the origin of the flatten order. Refer to the documentation here regarding this:
Trade Activity Log Analysis: Determining the Origin of a New/Modified Order
