Date/Time: Wed, 26 Feb 2025 14:27:48 +0000
activity log filter by Note problem
View Count: 498
[2021-05-20 18:12:42]
User61576 - Posts: 445
pls check the attached screenshots
as you can see if I filter by note, I am missing a trade though the note is identical
pls advice
Private File
Private File
Private File
[2021-05-20 21:24:12]
The note would be missing on the closing fill and that would be the problem.
[2021-05-21 03:42:22]
If that was the issues, than why that fill has a note at all?
Pls check screen shot, it shows that even if i select all notes and the fill is shown, it has the same note as tge others
[2021-05-21 14:25:50]
The entry fill has a note. But not the exit fill.
This is definitely not shown at all in the screenshots:
