Date/Time: Wed, 26 Feb 2025 11:48:18 +0000
Replay speeds not refreshing in chartbook.
View Count: 476
[2021-05-20 04:00:01] |
Tr@der17 - Posts: 12 |
When I'm trading, I have chartbooks that show me smaller charts, which I use as an overview. I have 5-6 of them in one chartbook window, and that's the entire chartbook. I'm having an issue with replay speeds. Because I'm just looking at these charts as an overview, I set the refresh time to 15k (15 seconds), so maybe that has something to do with the problem. But when I have the replay chart window open, and I change the speed, the charts aren't changing, or maybe one or two of them are changing, but not the others. So if I want to slow it down to .01 speed, it'll slow down one or none of them. I do this instead of pausing, because pausing causes me to lose the replay all together after a few minutes, and it goes back to "live". Same thing happens if I want to speed it up. The charts aren't following along. I do have "All Charts in Chartbook" selected as well. Please advise. Thanks. |
[2021-05-20 04:04:59] |
When you change the replay speed make sure one of the charts is active at that time.
[2021-05-20 06:58:05] |
So you mean, I may have had a chart active in another chartbook, and that's what's causing this issue? |
