Date/Time: Wed, 26 Feb 2025 11:50:35 +0000
download install
View Count: 1607
[2021-05-20 03:00:29] |
Steve Leon - Posts: 310 |
i am not able to download and install the software on Windows 10 i had the log but not sure if will be sent with this message or how to attach it it is saying download failure after every entry towards the end. I am using a Macbook Pro with Parallels and Windows 10. I am not sure if this is the issue ? |
[2021-05-20 05:48:22] |
Use the ZIP installer in this case: Software Download: Sierra Chart Zip Installer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
