Date/Time: Wed, 26 Feb 2025 12:05:36 +0000
Enable real-time data
View Count: 471
[2021-05-19 16:50:18]
Khoa Ho - Posts: 8
Hi, I have Tradovate to use everyday. But I don't see Tradovate connection on Data/Trade Service Settings. Can you please help me to connect SC to Tradovate.
Thanks.
[2021-05-19 17:08:28]
John - SC Support - Posts: 38172
You would need to find out what trading service tradovate is using. We know they support the use of CQG, so if your account is setup to use CQG, then you can connect your Sierra Chart to that account by following these instructions:
CQG Trading Platform Service: Setup Instructions
[2021-05-19 17:43:58]
Khoa Ho - Posts: 8
Hi, I don't know why SC Data - All Services does not work to provide real-time data. Can you have any simple way to enable it. It will take sometimes to contact Tradovate to find the solution.
[2021-05-19 17:51:17]
Because of rules from the CME Group. Refer to the following:
Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges
