Date/Time: Sun, 13 Sep 2026 04:46:20 +0000
Cant I get Denali and Sierra exchange to work with AMP/CQG
View Count: 772
| [2021-05-19 16:27:37] |
| User598100 - Posts: 2 |
I just enabled Sierra Data Exchange feed and activated the US equities exchange. Prior to doing that I already had the Denali data exchange enabled for futures and I am connected to AMP for order routing only (working just fine). But when I try to load stock charts it is not loading or finding the symbols... it seems to be a conflict with CQG setting in Data/Trade Services configuration and it is only allowing me to load futures symbols. Will I not be able to do both stocks and futures data on Sierra, even though I will only be trading Futures on the Sierra via AMP? (I am trading equities on another broker and just need the data on Sierra)
| [2021-05-19 16:58:40] |
| John - SC Support - Posts: 47854 |
The problem you are having is due to not having an active exchange selected for the Sierra Chart Exchange Data Feed. We see that you used to have the U.S. Equities exchange active, but it ended on April 30, 2021. You will need to reactivate the exchange by selecting the Activate button for the exchange on this page: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
