Date/Time: Wed, 26 Feb 2025 11:44:41 +0000
Can I import unusual CSV data into Sierra Chart?
View Count: 693
[2021-05-19 14:15:42]
User31751 - Posts: 2
What I would like to do is import Option Volume data and display it on a stock chart.
Does Sierra Chart support that functionality?
[2021-05-19 15:09:20]
John - SC Support - Posts: 38172
Refer to the information here for importing data:
Exporting and Importing Intraday Data Files: Import and Load
There are several links in that section to information on the Text/CSV Data Format. You will want to select that link to see what formats are supported.
[2021-05-19 15:35:30]
I already looked at those. They only seem to support pre-defined fields. I want to be able to import custom fields as an Indicator like RSI or MACD but instead of calculating the indicator from available fields like Open , Close, etc., I want to import the indicator from a CSV file.
For example, I might have a CSV file with the date and the Put Option volume for a stock and I would like to display that as a bar chart (like regular trading volume) in a panel below the stock price chart.
[2021-05-19 15:57:42]
To do something like what you are wanting would require you to program a custom study. Refer to the information starting here:
Advanced Custom Study Interface and Language (ACSIL): Introduction
[2021-05-19 19:36:01]
You definitely have to follow the required file formats supported. You can use the fields to contain whatever data you want. They will be drawn as a normal bar chart. There is a volume field.
Date Time Of Last Edit: 2021-05-19 19:36:45
