Date/Time: Wed, 26 Feb 2025 11:36:37 +0000
Volume on a Calendar spread
View Count: 487
[2021-05-19 10:09:11] |
User41683 - Posts: 37 |
Hi, How is volume calculated on a Calendar spread like on oil made by making a new symbol on Global Settings >> Symbol Settings? Because the volume number I will see on the Calendar spread chart is not the same as the volume of for instance two months added together. |
[2021-05-19 14:23:12] |
John - SC Support - Posts: 38172 |
Refer to the information here: Custom Calculated Symbols: Custom Calculated Symbols Volume Calculations For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
