Date/Time: Wed, 26 Feb 2025 12:06:18 +0000
Flatten position for previous month contract
View Count: 525
[2021-05-19 03:56:51] |
User987654 - Posts: 69 |
Hi Support, I am using ACSIL. I wrote some code that automatically reloads the chart once per day and if it detects a change in sc.Symbol I want to cancel all orders and flatten my position from the previous month contract. The issue is that once the chart reloads, it rolls to the next month (which is desired behavior) but the sc.FlattenAndCancelAllOrders() function only applies to the current symbol. Is it possible to add a Symbol argument to the function? I am open to other ways to accomplish the same thing. Thanks |
[2021-05-19 15:11:19] |
We will have to add a new ACSIL function for this.
[2021-05-19 21:44:30] |
That would be very helpful, any idea on ETA?
[2021-05-19 22:55:14] |
It will be out in the next release. This function only works though for non-simulated trading. Not simulated trading. The function is: FlattenAndCancelAllOrdersForSymbolAndNonSimTradeAccount Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-05-19 22:56:41
