Date/Time: Sat, 18 May 2024 19:50:32 +0000
[Programming Help] - draw volume profile
View Count: 2964
[2022-05-24 19:28:51] |
User586297 - Posts: 34 |
Hi there, Just refilled Sierra Charts and have transact account. Am still getting delayed info. May you help. |
[2022-05-24 21:10:47] |
Our servers are showing that your Sierra Chart is not setup to connect to your TransAct account, rather it is just connecting to our (Sierra Chart) servers. This, in combination with the fact that you are not setup to get any real-time data from us, is why you are getting the delayed data. If you need to connect to your TransAct account, then you need to go through the Setup Instructions at the following link: https://www.sierrachart.com/index.php?page=doc/TransAct.php#SetupInstructions Otherwise, let us know what you want to do, and how you want to get setup and we can help you from there. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-24 21:50:23] |
Hi, From SC data to tranact ws data. it doesn't show u/m and p/w. |
[2022-05-25 13:43:46] |
We do not understand what the issue is. Can you please give us some more information and possibly a screenshot or two to help point out where the problem is.
[2022-05-25 19:07:03] |
Hi, Is transact and SC compatible? |
[2022-05-25 22:28:40] |
Hi, To receive current and not delayed data, need to Enroll in Standard Sierra Chart with Denali Exchange Data? Just enrolled in Sierra Chart with Advanced Features, may you change it to Denali Exchange Data? |
[2022-05-26 14:07:34] |
First of all, refer to the following regarding TransAct and Sierra Chart: Important Priority Notice to Transact Users. Date: 2022-05-25 In terms of getting setup to use the Denali Exchange Data Feed, you need to go through the Setup Instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-08 00:03:22] |
Hi, Who's better Stage 5 or Edge Clear? |
[2022-06-08 17:03:15] |
Stage 5 Trading - Posts: 152 |
Hi Trader, Stage 5 fully understands and appreciates the trials and tribulations of changing brokerage firms. Which is why we take great pride in helping traders transition as seamlessly as possible. Personally, I believe the best solution is to switch to Sierra Teton Order Routing with Denali for real time and historical data. This is all maintained by Sierra directly, which I feel provides great benefits to traders as Sierra can focus on enhancements instead of maintenance of other third party order routing feeds. In addition, I feel it is the best overall quality and value for traders. You can open an account for as little as $100 and you will receive $0.20 per side commissions on the micros and $0.45 commissions on non micros plus exchange and regulatory fees. Please feel free to contact us and we will gladly assist you with any questions you may have and/or the process of transitioning your account and hopefully helping you improve your current trading solution. We would be able to provide some DOM chartbook layouts that will hopefully be more in line with what you are accustomed to. In addition, we would be more than happy to have a remote session to help get you setup with the new layouts. If you have questions or would like to speak to an assigned personal broker for details, please call us at 1-312-896-9897 or 1-800-258-6675. You can email us at sierrachart@s5trading.com and can also contact us here: https://stage5trading.com/contact/ If you are ready to move to the Teton Order Routing solution right away, we invite you to complete an application by clicking the blue button at the top of the https://stage5trading.com/ page that says Introducing Sierra Chart Teton Order Routing - Click Here to Open an account Thank you, Anthony Giacomin Stage 5 Trading Trading derivatives carries a high degree of risk, and may not be suitable for all investors. Past performance is not necessarily indicative of future results. |
[2022-06-30 19:47:20] |
HI, I have the color background based on alert condition =C>=L[-1] LET'S SAY RSI OR ANY INDICATOR AND TRIGERS A LONG (BUY) SIGNAL. HOW TO SHOW THE First Signal ON THE FIRST BAR BASED ON =C>=L[-1] and Ignore Multiple Signals ON THE COLOR BACKGROUND? THANKS. |
[2022-07-14 20:04:17] |
Hi Sir, on the Supported Exchanges what is best to use for ES. |
[2022-07-14 20:56:19] |
For the ES, you need the CME exchange. But as to which one is up to you. It depends on whether you need Market Depth data or not, and whether you need other CME Group exchanges or not.
[2022-07-15 04:46:13] |
WHAT CHART SERVICE WAS I USING.
[2022-07-15 05:28:22] |
HI, I have the color background based on alert condition =C>=L[-1] LET'S SAY RSI OR ANY INDICATOR AND TRIGERS A LONG (BUY) SIGNAL. HOW TO SHOW THE First Signal ON THE FIRST BAR BASED ON =C>=L[-1] and Ignore other Signals ON THE same COLOR BACKGROUND? THANKS. |
[2022-07-15 15:14:35] |
We are not understanding this question. You are not currently setup to get any real-time data from us (Sierra Chart). I have the color background based on alert condition =C>=L[-1]
LET'S SAY RSI OR ANY INDICATOR AND TRIGERS A LONG (BUY) SIGNAL. HOW TO SHOW THE First Signal ON THE FIRST BAR BASED ON =C>=L[-1] and Ignore other Signals ON THE same COLOR BACKGROUND? This is a Programming Help question, which is why the thread is set to "Programming Help". It is beyond the scope of our support. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-07-15 18:33:25] |
Have transact future in order to use it need to get stage 5 or edge clear, have edge clear. not listed in the data trading ? please help |
[2022-07-15 21:20:56] |
Did you tell Edge Clear that you wanted to use the Teton Order Routing Service with your Edge Clear account? If so, and they have you setup, then go through the instructions at the following link starting at step number 5 (you will need to setup the Denali Exchange Data Feed in order to get data when using the Teton Order Routing Service): Sierra Chart Teton Futures Order Routing: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-04 03:30:41] |
Hi again, how to get hi, low lines based on =C>=L[-1] thanks sir |
[2022-12-13 21:05:13] |
Hi Sir, How to connect to teton real time. Have edge clear with ironbeam. May you help. thanks |
[2022-12-13 21:19:43] |
You need to setup the Denali Exchange Data Feed for your data. Follow the instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-31 21:13:54] |
HI SIR, MAY YOU HELP WITH AN ISSUE IN HOW TO RESTORE MISSING CHART DATA? THANK YOU. |
[2023-02-01 15:47:42] |
If you are missing chart data but have data in the chart (i.e. you have a hole of missing data), then refer to the following: Data Errors or Spikes in Charts, Flat or Flat Line Graph, Compressed Graph, Errors with Date/Time Values: 2.1.2 Deleting and Re-downloading Data. (Easier and Recommended Method) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-16 00:41:31] |
HI SIR, IS THERE A WAY TO MAKE A HISTOGRAM? |
[2023-02-16 15:00:56] |
The main histogram is created by using the Volume by Price study. Refer to the instructions and information here: Volume By Price Study: Step By Step Instructions If you are looking for something else, then we would need to know what kind of histogram you are wanting. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-05 20:13:12] |
https://www.sierrachart.com/image.php?Image=1678046908850.png
[2023-03-06 17:53:35] |
We are not sure exactly what you are wanting to do from the image you give. First, we see that you have the Price Calculator drawing tool being used for the Price Difference. If this is not your image and that is what you are looking for, then refer to the following: Chart Drawing Tools: Chart Calculator Second, if you are wanting to get the price difference programmatically, then do you want it for the current bar when the Close is greater than or equal to the Low of the previous bar? But how does this relate to the Chart Calculator drawings that cover multiple bars? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
