Date/Time: Wed, 26 Feb 2025 11:53:32 +0000
What kind of subscription?
View Count: 480
[2021-05-18 16:29:50] |
giudi - Posts: 5 |
I have to make simulated trading: can I do it even with late data? In this regard, can I do with the Advanced package, or do I have to continue with Advanced + Denali Data Feed? regards |
[2021-05-18 16:40:26] |
John - SC Support - Posts: 38172 |
You can use the Delayed exchange data feed for simulated trading. In fact, we encourage it, as it works in all ways the same as the real-time data, but it does not cost anything. Refer to the information here: Delayed Exchange Data Feed All Sierra Chart packages offer access to the Delayed Exchange Data Feed, and Simulation mode and the Simulated Futures Trading Environment. Therefore, the choice of package should be based on the whether you need the items that are only available in the Advanced Package such as TPO charts and Numbers Bars. You will find the difference between the packages here: Description of Service Packages and Pricing: Packages If you do use the Delayed data, then you do not need the Denali Data Feed at all, therefore it would just be a choice between Package 3 or 5. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
