Date/Time: Wed, 26 Feb 2025 11:31:52 +0000
chart resizing by itself
View Count: 540
[2021-05-18 13:57:14]
User951413 - Posts: 13
Why does the chart automatically resize itself when I do a scale resize on the scale(up and down resize)?
[2021-05-18 14:41:42]
John - SC Support - Posts: 38172
It sounds like you are saying that when you adjust the scales, the chart is jumping back to a different state than what you wanted when you changed it. This should not be happening.
We would need more specific information on what your Scale settings are set to and what exactly you are seeing. Also, is this a Trading DOM or a chart?
[2021-05-18 16:39:55]
Yes when I drag the scale up or down, it then starts to readjust itslef slowly. Im using the chart DOM, Interactive Scale Setting and Scale Range Setting.
[2021-05-18 16:46:50]
It sounds like you have your scale settings set to Constant Range with the Constant Range Scale Mode set to Re-Center When the Last Bar Exceeds a Certain Number of Ticks from the Center. But even so, it should not be changing the chart when you manually make a change.
Check your Chart Settings and let us know exactly what the Scale Range options are set to. Refer to the following for what we are looking for:
Chart Scale and Scale Adjusting: Scale Range (Scale Settings)
