Date/Time: Wed, 26 Feb 2025 10:18:32 +0000
AMP Real Data
View Count: 536
[2021-05-17 18:28:17] |
antonitrujols - Posts: 13 |
Hi, i remember that there was a deal to get the CME data through AMP Futures and that way it costed 34 usd/month instead of 110usd/month. I can't find the link anymore. I was also told there was a way usin an api from AMP. What should i do? Thanks, Arnau.
[2021-05-17 19:34:54] |
John - SC Support - Posts: 38172 |
What you are referring to is the CME Group requirement to have a live, funded, futures trading account in order to qualify for the lower-priced non-professional exchange fees. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges Therefore, if you have an account with AMP using CQG for your order routing, then you will meet this qualification. We are still working on the API to do automatic qualifications of accounts with AMP. But if you have your trading account with them, then you can just keep your account linked to your trading account and you would not need to worry about this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
