Date/Time: Wed, 26 Feb 2025 09:58:58 +0000
Historical data from Gain Capital
View Count: 544
[2021-05-17 16:17:51] |
gretat - Posts: 11 |
http://www.sierrachart.com/image.php?Image=1621205385151.png http://www.sierrachart.com/image.php?Image=1621205905896.png Hello, I have signed up for the denali data feed ($36.00/mon) I have gain capital for my trading account and I have switched to their data. My Mes chart is showing historical data as I expect, however my MNQ chart is only showing a shortened amount of data. I have one chartbook with both charts in it. Can I use the SC denali feed for my data and still use Gain Capital for my trading account? Greta |
[2021-05-17 18:33:39] |
John - SC Support - Posts: 38172 |
First - Yes, you can use the Denali Exchange Data Feed and trade through Gain Capital. Check the Session Times for the MNQ chart to ensure that they are set properly, along with the number of days to load. Refer to the following: Chart Session Times If this is a data issue from Gain Capital, then we can not say what the issue may be. You can try Edit >> Delete All Data and Download to see if that will resolve it. In the end, we really do recommend using the Denali Exchange Data Feed instead. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
