Date/Time: Mon, 28 Sep 2026 10:04:49 +0000
[User Discussion] - background color not change from another chartbook
View Count: 1203
[2021-05-17 15:34:43]
inusuel - Posts: 11
I create a some graph in a chartbook .
If i want to change the background of the graph include with this chartbook , i use ( global setting / graphic setting - global / chart background) to change the color of the graph
Everything work well , with the chartbook i created.
but somebody give me a new chartbook he did himself .
i use it , but impossible to change the background color of the graphs of this new chartbook .
I try this way ( global setting / graphic setting - global / chart background) , but it didnt work .
Why ?
[2021-05-17 17:58:47]
John - SC Support - Posts: 48028
Because the person that gave you the Chartbook changed the background for that specific chart by changing it under Chart >> Graphics Setting - Chart.
If you just want to change the settings to your global settings, then go to Chart >> Graphics Settings - Chart and enable the option at the top for Use Global Graphics Settings Instead of these Settings. Refer to the following:
Graphics Settings: Use Global Graphics Settings Instead of These Settings
