Date/Time: Wed, 26 Feb 2025 09:55:30 +0000
Multiple contract error
View Count: 448
[2021-05-17 14:53:17]
User28317 - Posts: 149
I ran a backtest using 2 contracts, instead of one and got an error on YM. Is there a setting that I missed?
[2021-05-17 14:55:59]
What error is this?
[2021-05-17 16:10:50]
It ays "multiple positions on same direction is not enabled".
imagemultiple positions is not enabled.JPG / V - Attached On 2021-05-17 16:09:29 UTC - Size: 305.9 KB - 173 views
[2021-05-17 18:21:46]
John - SC Support - Posts: 38172
Then you have exceeded the settings for your study, in particular it sounds like there is a limit on the number of positions that can be open. You would need to look at your study and see what the settings are.
