Date/Time: Mon, 25 Nov 2024 20:28:17 +0000
ACSIL - SCTimeAndSalesArray for a different symbol
View Count: 1187
[2014-03-12 05:56:35] |
ejtrader - Posts: 688 |
SC Team - Is it possible to access T&S information for a different symbol than the symbol where the study is applied to? If not - would it be possible to add this function if you don't anticipate technical difficulties implementing it? Thanks |
[2014-03-12 09:35:57] |
This already exists: sc.GetTimeAndSalesForSymbol(const SCString& Symbol, SCTimeAndSalesArray& TSArray); Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
