Date/Time: Fri, 07 Feb 2025 14:57:29 +0000
cumulative delta divergence study
View Count: 2459
[2021-05-14 16:14:19] |
User582874 - Posts: 2 |
Hello I am trying to find a divergence study between cumulative delta and price. For example if price makes a higher high but cumulative delta does not. |
[2021-05-14 16:59:43] |
John - SC Support - Posts: 37808 |
It sounds like you are wanting an Alert, not a study. But, take a look at the Divergence Detector study to see if it does what you want: Divergence Detector If we are understanding what you want, then you should use the Color Bar Based on Alert Condition study. You may have to put together a few studies with it, just as High/Low for Time Period in order to establish your baselines and then create your alert from there. Refer to the following: Color Bar Based on Alert Condition Note this particular section of the Color Bar Based on Alert Condition study: Color Bar Based on Alert Condition: Drawing Arrows/Text or Other Styles at the High or Low of Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
