Date/Time: Wed, 26 Feb 2025 10:01:20 +0000
IBKR IdealPro FX Data
View Count: 672
[2021-05-14 12:37:53]
User78442 - Posts: 260
My IBKR FX data no longer works, it was OK yesterday. Any ideas?
[2021-05-14 16:22:37]
John - SC Support - Posts: 38172
You can get us your Message Log and there might be some information in there, but offhand we would say that you probably need to ask IB about this.
Follow these instructions to get us your Message Log:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2021-05-14 21:51:52]
Contact Interactive Brokers. Also refer to this help topic:
https://www.sierrachart.com/index.php?l=helpdetails3.html
[2021-05-17 04:59:09]
This morning the feed started working ... not sure what the problem was ... I think it was a symbol mismatch that IBKR fixed... thanks for your efforts
