Date/Time: Wed, 26 Feb 2025 10:14:16 +0000
VIX and Bonds Yields
View Count: 604
[2021-05-14 10:29:04] |
User893396 - Posts: 40 |
Hello, Is it possible to have US Treasuries YIELDS and the VIX and what are the symbols? I have package 12 - Advanced MBO + Denali Data Feed / CQG WebAPI. For the yields, if I put the symbols found here, I get a "symbol unknown" message. For the VIX when I select $VIX from the available symbols, I have a "download failed", "unauthorized user" message. Thanks |
[2021-05-14 16:18:53] |
John - SC Support - Posts: 38172 |
We do not have the US Treasury yields. With regards to the symbols listed on that one page, we will check on those, but it looks like they are no longer being furnished by our data provider. With regards to the VIX, the CBOE made a change awhile ago so that even historical data is no longer available unless you pay for the exchange. So if you really need the VIX, then you would need to use the Sierra Chart Exchange Data Feed and enable the CBOE Indices exchange. Refer to the information on this page: Sierra Chart Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
