Date/Time: Mon, 02 Nov 2026 05:17:35 +0000
New study proposal: TPO letters on the 30m footprint chart
View Count: 991
[2021-05-14 10:01:51]
RIFT - Posts: 124
Is it possible to do a study, with which I can assign the letters to the 30m footprint chart (see the screenshot)?
It would be great if they did!
Thanks!
Best,
RIFT
imageTPO Letters.png / V - Attached On 2021-05-14 10:01:14 UTC - Size: 422.57 KB - 413 views
imageTPO Letters2.png / V - Attached On 2021-05-14 10:01:21 UTC - Size: 62.84 KB - 465 views
[2021-05-14 14:14:08]
mrseho - Posts: 25
+1
[2021-05-14 16:27:22]
There is not a built-in study that would do what you want. It could definitely be developed using ACSIL though. You could draw a text drawing for each letter you wanted to place.
Refer to the information starting here:
Advanced Custom Study Interface and Language (ACSIL): Introduction
[2022-05-14 16:39:24]
SavantTrader - Posts: 112
There is no need to code a custom ACSIL study for this - it already exists.
Use the study "Time Line" - See my attached chart (I-period and beyond).
imageCapture.PNG / V - Attached On 2022-05-14 16:39:03 UTC - Size: 110.81 KB - 315 views
