Date/Time: Wed, 26 Feb 2025 13:59:48 +0000
Rolling time frame window signal generation
View Count: 638
[2021-05-13 23:31:41]
User945898 - Posts: 7
Thank you for your previous reply it was very useful.
I want to be able to scan on any time frame bar chart and highlight the specific 2 bars within a 48 hour rolling time frame window as follows:
If the current bar close time and price is above the close time and price of the bar exactly 48 hours ago (2 days ago or 48 bars ago) on an hourly chart.
Then link the 2 bars, the current bar and 48 hours ago, with the top and bottom lines of an extending flashing rectangle and highlight the bar 48hrs ago with a down arrow and the current bar with a up arrow and an audio alert for clarity.
And if the current bar close time and price is below the close time and price of the bar exactly 48 hours ago (2 days ago or 48 bars ago) on an hourly chart then the 2 bars would be linked again with signals given in the opposite directions on each bar respectively.
I would like to do this with different time frame windows. E.G. 8 hours, 16 hours, 81 hours. ETC.. on the same chart
No signals if conditions not met
Both bars current and 48 hours ago must engage and close within say a difference of 1 point(make this adjustable if possible
Hope that is clear.
Zafar
[2021-05-21 01:45:58]
Hi SC suppoort
can you please advise me if my previous request for support "Rolling time frame window signal generation" is able to be done by using existing SC functions and if so please guide me in the right direction.
If new coding is needed and you are able to do this i will be happy to pay a reasonable fee?
Thank you
[2021-05-22 05:39:22]
See the answer here:
RE: Rolling time frame window signal generation request
