Date/Time: Wed, 26 Feb 2025 09:55:20 +0000
How to change trade activity log time zone?
View Count: 1156
[2021-05-13 20:22:59]
theunknowntrader - Posts: 112
I do not know where to change trade activity log time zone. I tried general settings/data trade service settings and there is nothing there.
[2021-05-13 20:45:58]
John - SC Support - Posts: 38172
When you are viewing the Trade Activity Log within Sierra Chart, it is going to use the Time Zone that is set for the Chart, which is under Chart >> Chart Settings >> Advanced Settings. Most of the time, this is set to use the Global Time Zone.
The Global Time Zone is found now under Global Settings >> Time Zone Settings.
But, we are wondering if you are looking at the exported Trade Activity Log information, which is in UTC time. The time zone for that information can not be changed. Refer to the following:
Trade Activity Log: Importing and Exporting Data
Also note, as stated in the above documentation for exporting the Trade Activity Log, you can get the information in your time zone by using the Save to Text File option. Refer to the following:
Trade Activity Log: Saving to a Text File
