Date/Time: Wed, 26 Feb 2025 10:05:56 +0000
Feature Request: Naming Drawings (Horizontal Rays), Name Part of alert message
View Count: 460
[2021-05-13 14:46:50]
User566851 - Posts: 20
Hello:
I have a feature request and understand it may not be possible. It would be great if there was a box on the chart drawing properties tab to name the chart drawing. In the alert section, there should be a check box to transmit the name in the alert message.
Reason for feature: Text message alerts can be a little confusing if there are multiple alerts on the chart at the same time. This would help give context to the alerts.
Current feature: In the alert tab you can name the alert and there are 200 available alert names. This is essentially what I am looking to do and have been using this path, however it creates an extra step (set alert on chart drawing, then go to general tab 3 name new alert, possibly go back to chart drawing alert and make sure the new name is still selected) and more alerts to manage.
Realistically all my different alerts are the same, just with different names to give me a message when I receive a text.
Added bonus feature: Save default alert settings in chart drawing properties. Most of my alerts are just Last -> crossing or equal to -> Alert Name -> Only trigger once. There should be a way to save this.
Thanks for reading and I understand you guys are working on some actually important items. These requests would be the cherry on top to make my work flow (and Im sure many others) more streamlined.
