Date/Time: Wed, 26 Feb 2025 14:04:57 +0000
Erase All Text/Lines Prompt.
View Count: 543
[2021-05-13 09:16:23]
User92573 - Posts: 547
Dear Support
I've read through:
See screen shot. As well as looking through Global Settings >> Tool Settings but could not find where the Erase All Text/Lines >> Prompt settings are located.
I also looked through the Windows System Sounds but cannot seem to find a way to remove the sound from this event.
The Prompt is really useful but as the general volume for alerts can be pretty high you can imagine a sound prompt each time a text/drawing is deleted can be a real nightmare and resulting hair style close to that of Dennis the Menace (example attached).
Any help appreciated.
Many thanks
Private File
Private File
[2021-05-13 14:33:04]
John - SC Support - Posts: 38172
The option for Prompt when Deleting all Chart Drawings is on the Tool Settings window (Tools >> Tool Settings). Refer to the setting here:
Chart Drawing Tools: Prompt When Deleting All Chart Drawings (Global Settings >> Tool Settings >> General >> Other)
[2021-05-24 13:20:24]
Thank you John - that's where I was but obviously I hadn't looked closely enough.
