Date/Time: Wed, 26 Feb 2025 09:46:40 +0000
Issues with a new intraday chart
View Count: 476
[2021-05-13 07:39:14]
User727773 - Posts: 14
I am trying to make a new intraday chart from intraday data that I imported from one of my .scid files. The problem I get is when I make a new intraday chart, it seems to interpret my data as daily chart data even though its intraday data that I was exported from one of my .scid files. So it loads up a daily chart instead of an intraday chart. I have attached the 2 charts as well as the data file in CSV format. If you could look into this, I would much appreciate it. Thank you.
Private File
imageintradaychart1.JPG / V - Attached On 2021-05-13 07:38:45 UTC - Size: 55.75 KB - 170 views
imageintradaychart2.JPG / V - Attached On 2021-05-13 07:38:49 UTC - Size: 74.6 KB - 202 views
[2021-05-13 14:23:36]
John - SC Support - Posts: 38172
How are you opening the CSV file? If you are opening it directly, then it is going to interpret it as daily data, as the daily data is stored in an ASCII format.
If you want to get the data into the system as Intraday data, then you need to use the Import method. Refer to the following:
Exporting and Importing Intraday Data Files: Import and Load
