Date/Time: Wed, 26 Feb 2025 10:00:06 +0000
Cannot install V 1938
View Count: 470
[2021-05-13 03:32:32] |
User273624 - Posts: 10 |
Trying to install version 1938 through the help >> install previous version menu. Installer 10 is what I have. When putting in specified version: 1938, it shoots back an "Incorrect URL when getting common files list to download" error. I've sent the log to support. Thanks, |
[2021-05-13 14:12:51] |
John - SC Support - Posts: 38172 |
You will not be able to install a version that is that old. Refer to the information here: Using Sierra Chart Current Versions is Required and Historical Data New Policy For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
