Date/Time: Mon, 25 Nov 2024 20:26:28 +0000
Saved over my chartbook :(
View Count: 1267
[2014-03-11 21:02:37] |
100 - Posts: 147 |
Is there a way to recover an old chartbook file? I still have the chartbook running, and I'm just praying to god I don't have to rebuild a chartbook. Is there a file that is logged or hasn't been written over that I can use?
[2014-03-11 21:29:58] |
100 - Posts: 147 |
Nevermind! You should include a delete button for threads. Open file location, find file, right click and select restore option. |
[2014-03-11 21:37:37] |
At the top of the thread there is the "Hide" button. This is effectively a delete. There are backup Chartbooks which are available which you can use: https://www.sierrachart.com/index.php?l=doc/doc_Chartbooks.html#BackupChartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
