Date/Time: Tue, 15 Sep 2026 13:09:08 +0000
Market Depth levels for chart
View Count: 935
[2021-05-12 13:20:49]
User731023 - Posts: 167
Sorry could not find.
How do you adjust how many levels for ES on a chart.
(Using market depth historical graph)
[2021-05-12 15:37:01]
John - SC Support - Posts: 47889
There are a number of different methods to limit the number of levels on a chart. It just depends on what you are actually wanting to do.
First, if you want to change the number of levels that are received from the Denali Exchange Data Feed, which will then affect all the places where Market Depth is displayed, then refer to the following:
https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#MaxDepthLevels
If you just want to limit the number of levels displayed on the DOM, then refer to the following:
Chart Settings: Maximum Market Depth Levels (Chart >> Chart Settings >> Market Depth menu)
And finally, if you are wanting to limit the number of levels displayed in the Market Depth Historical Graph, then refer to the following:
Market Depth Historical Graph: Maximum Levels to Display (0 for All)
