Date/Time: Wed, 26 Feb 2025 09:58:17 +0000
Denali data adding stock data
View Count: 509
[2021-05-12 09:51:22] |
User220914 - Posts: 239 |
Hi, If I pay for stock or equity data can I get it in Sierra with denali. I know denali for cme etc. I used to have stocks n futures when I used the barchart data |
[2021-05-12 15:15:12] |
John - SC Support - Posts: 38172 |
Yes, you can add the U.S. Equities, which is part of the Sierra Chart Exchange Data Feed, to your account and get both in the same installation of Sierra Chart. There is no issue with this. Refer to the information on the Sierra Chart Exchange Data Feed at the following link, which also includes the Setup Instructions: Sierra Chart Exchange Data Feed For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-05-13 13:57:12] |
Thank you for your fast response as always! I want to make sure that this is crystal clear for myself and for others who may read this in the future. I am using DENALI a great feed by the way for CME futures data. I want to add nyse equities which have an exchange fee of 10.50 per month. I would need to sign up for either the 250 symbol sierra chart data feed for 25 per month or the 750 symbol for $ 50 per month and pay the 10.50 exchange fee correct? So i would for the 250 symbol be payng 25 dollars plus 10.50 so My total would be $ 35.50 for the nyse exchange data. There is no longer a base price for the sierra data feed except for the 250 symbols as a minimum correct. Question. If i wanted to drop denali would this sierra chart exchange data feed also allow me to get teh real time data for the CME? if i was not worried about too many symbols that is? thank you. also is it more economical to use the sierra chart exchange data feed or (SCEDF) with cme bundle and stocks nyse versus denali and the (SCEDF)? no issue paying for data just want to fully understand how it works now thank you in advance |
[2021-05-13 15:14:07] |
Correct.So i would for the 250 symbol be payng 25 dollars plus 10.50 so My total would be $ 35.50 for the nyse exchange data.
Correct.There is no longer a base price for the sierra data feed except for the 250 symbols as a minimum correct.
Correct. The 250 symbols for $25.00 is the base price and then the exchange fees are in addition.Question. If i wanted to drop denali would this sierra chart exchange data feed also allow me to get teh real time data for the CME?
No, this is not available. The CME Group and EUREX is through the Denali Exchange Data Feed and the other exchanges are through the Sierra Chart Exchange Data Feed.if i was not worried about too many symbols that is? thank you. also is it more economical to use the sierra chart exchange data feed or (SCEDF) with cme bundle and stocks nyse
No, there is no other method to get the data from us. You would need to use the Denali Exchange Data Feed for your CME Group data and the Sierra Chart Exchange Data Feed for the U.S. Equities.versus denali and the (SCEDF)? We are working on a new NASDAQ integration that will be part of the Denali Exchange Data Feed. We hope to have this ready in a few months. Once that is available, you would be moved over to it, but until then, the above information is the way to go. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
