Date/Time: Wed, 26 Feb 2025 05:15:18 +0000
CQG and Denali
View Count: 584
[2021-05-11 03:23:16] |
User473031 - Posts: 55 |
I'm currently using Denali BMO and CQG with AMP as broker. Originally, everything was through AMP before the change. I have discovered that when data is set to SC that I should have Denali Data Feed and CQG routing. However, when I try to place a live trade it will automatically go to Trade Simulation. I've gone over the settings and they are correct. Can you tell me how to fix this? Thanks |
[2021-05-11 06:49:42] |
User907968 - Posts: 833 |
You need to select CQG in the data trade services window and enable support for sierra chart data feeds, selecting SC Data - All Services provides a data only connection, so trading would not be possible. Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services Data/Trade Service Settings: Allow Support for Sierra Chart Data Feeds (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Other Settings) |
[2021-05-11 06:59:35] |
Yes, refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services And: CQG Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
