Date/Time: Wed, 26 Feb 2025 05:28:20 +0000
Couldn't fine MES in Denali Data Feed Symbol List
View Count: 552
[2021-05-10 21:46:00]
Tony - Posts: 549
Just started using Denali Data Feed today, it works great.
I couldn't fine MES symbol in this page:
https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Futures#gblx
and wondering if MES is included or not? if not, can I still get live
feed from my broker? (IB)
Thanks a lot
[2021-05-11 02:07:24]
58LesPaul - Posts: 429
You need to update the symbols(Global Settings > Update from server) and then find symbol(File > Find Symbol.
[2021-05-11 04:08:53]
Tony - Posts: 549
Thanks Paul, I just noticed [M] at the end of MES symbol on my chart, so I assume it is included
in Denali Data Feed, still wonder why it is not listed on Sierra's web site though.
[2021-05-11 14:22:31]
The symbols on that page do not use standard exchange symbols. They are from the provider Barchart.
