Date/Time: Sun, 04 Oct 2026 09:10:07 +0000
Cum vol of trades over a certain size
View Count: 672
[2021-05-10 18:19:16]
User339484 - Posts: 71
I want to keep a delta cum of trades of a certain size.
I tried:
Bid volume:
Study formula and referenced Bid Volume if trade is over 5 so I did basically =IF(ID1.SG1>1,ID1.SG1,0)
The study formula works
Now I did cum sum of study
that does nothing.
[2021-05-10 20:16:37]
John - SC Support - Posts: 48095
In the Cumulative Sum of Study study, do you have the correct reference to the subgraph in the Study and Subgraph to reference?
The next thing to check is if you have a flat line that extends across the entire chart at that point, then you will not have any scales displayed and the line will just be at the top of the region. If this is the case, then just scroll back in time, or compress your scale to have more bars, and you will then see the Cumulative Sum of Study show up.
If these do not help, then give us a screenshot of what you are seeing.
